The additional columns of a tree can be hidden using SetTreeColumnAttribute() with ATTR_COLUMN_VISIBLE parameter. This is an easy and effective way.
For a table this attribute isn't supported, so you can use some workaround that requires more coding and have some disadvantages (for example if you set the width to the minimum value of 1, the user can increase it with the mouse...).
I think that the ATTR_COLUMN_VISIBLE parameter would solve this needs in the perfect way.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
