z-values on 3d graph
Hi there,
I was wondering what can I do to make the z-axis have values visible. The video is running OK but there are no values showing up
on the z-axis, only these zeros. Also the same happens on an intensity graph connected to it. I would appreciate your help. Thanks!
(2,596 Views)
What is the range of values on the Z axis? If the values were from like 0 to 0.1 and the display format was set to no decimal places, this is exactly what I would expect to see. Check the axis display format.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,583 Views)
