y1,y2,y3,... plots
How to draw mulktiple Y1, Y2, y3..... Axes XY graph..
(2,972 Views)
hello,
use an xy graph and place mouse on it
in help window it is said you need to build array of xy
here an attachement for two xy curves
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,953 Views)
Your question is not clear enough. Please spend another minute explaining what you really want. Do you want multiple plots or multiple axes? Maybe you could attach an example containing typical data, for example.
An XY graph can have multiple plots. It can also have multiple scales for each axis. Each plot can be assigned to any of the scales you have configured.
What is the current type of your data? XY graphs take a wealth of data types for multiple plots (arrays of clusters where each cluster contains an x array and y array, arrays of clusters where each cluster contains a complex array, etc.)
One possible data structure is shown in the upper part of the illustration of this idea. See also this old thread.
(2,943 Views)
