01-28-2021 11:41 PM
I have a problem of the Y-axis shifting position when I programmatically turn off and then back on both axes of an XY graph. This problem is history-dependent, unfortunately. The attached VI shows two superficially identical XY Graphs. Each time the VI is run, the Y axis shifts on the top graph, but not on the bottom graph.
The first graph was cut and pasted from another VI, where it had been manipulated many times successfully, and only recently shows this problem.
The second graph was created new in the attached VI.
I have tried doing a right-click/replace/graph/XYgraph for the offending graph, but the problem remains even though the graph appears new.
01-29-2021 07:07 AM
You don't have any data on the graph saved so we can see what you are talking about.
01-29-2021 02:06 PM - edited 01-29-2021 02:08 PM
This is just an axis problem. Every two times the VI is run, the y axis will reappear a little further to the left, in the top graph only.
Allan
