Thanks for the instant reply David. I might not be able to understand some Labview words. When you said " use array manipulation", I dont know what you might be referring to. If I understand properly, it would be "build array function". If I use this then the output array would be a 2D array, which I still cannot feed to "Replace array subset".
By array manipulation, I mean that you can use any part of
the array pallet to insert/delete/overwrite your data as you please. I have
attached a picture of how you would get the Y values for 2 waveforms, and then replace
array subsets for both of them. Hope this example helps, but please keep in mind it is just one way to do this. You may alter the array data as you please.
Hi David, I was finally able to figure out the problem. I had to just set the DAQmx Read to N channel 1 Sample. I really appreciate your time in helping me solve the problem. I was able to solve the problem by reading and manupulating stuff that you used to send.
Thank you very much for posting back the resolution, and
explaining what steps were taken to resolve the problem. This will help the
community and future viewers. I am glad I could help, and appreciate the
comments!
