xy graph with double (or more) y scales
Right click on the chart and go to the Scales Tab of the chart properites.  You can set the offset and multiplier for the x-scale.  You can also set the display format on that tab to make it display as relative time.
Message 11 of 15
(1,606 Views)
Is it possible to have on marked possition actual time?
Vlado
Message 12 of 15
(1,593 Views)
Accepted by topic author California_J
Set the offset value for the x-axis to be the starting time.
Message 13 of 15
(1,583 Views)
Thanks.
Vlado
Message 14 of 15
(1,573 Views)
How to get X scale to count from zero again after midnight?
Vlado
Message 15 of 15
(1,544 Views)
