I have wrote a simple program (attached) to display two measured value pairs which then are displayed in an xy-graph. The two values are related to each other in the x and y axis. The problem now is that the program shows only the actual value as a point in the graph. My task is to create a program which shows and displays all the measured values as long as the "run" button is pressed continuously. Can someone give me an example? Many thanks
In a previous post, you were refered to the example Variable-Time Chart XY.vi. This example has shipped with LabVIEW for quite a long time. Select Find Examples under the Help menu, click the search tab, and enter xy for the keyword.
