xy graph active plot property settings not working
I set the xy graph plot properties manually and they appear to work. However, when I try to set them in the program they revert to the manual settings. What's going on?
PaulG.
LabVIEW versions 5.0 - 2020
“All programmers are optimists”
― Frederick P. Brooks Jr.
(2,954 Views)
The code you posted should set the properties correctly. Some options:
  1. You're working on another control than the one you think.
  2. You're resetting the controls somewhere.
  3. You're doing it in a reentrant VI and you're only changing one of the clones.
  4. You're changing it and then unloading the VI without saving.
Basically, without seeing the actual code, I don't see a way to tell for sure.
___________________
Try to take over the world!
(2,947 Views)
Accepted by PaulG.
I went to the graph and made plot legend visible and extended it from one plot to 3. That's all I did. Now it appears to be working properly. It's been a long while since I had to get really fancy with a graph but I don't remember having to do this. My memories of  graph properties were that they were a little more dynamic. Smiley Surprised
PaulG.
(2,934 Views)
