xy chart time
You need to display the x axis in a time format. Do you have a problem formatting the axis or do you have problems creating the correct data structure for the graph?
Also, if your timing is constant, all you need is a plain chart. Write x0 when the program starts (i.e. outside the loop, via a property node).
Message 11 of 15
(502 Views)
I have a problem creating the data structure. The time I think will be constant, but that could change in the future.
Message 12 of 15
(498 Views)
That's a very important distinction. if the dt varies over time, you need an xy graph and much more complicated data structures. If dt is constant for a given run, all you need is a chart.
Message 13 of 15
(485 Views)
Here's using an xy graph, allowing for variable time increments.
This is just a quick draft. Note that the data structures grow without limit, so you need to implement measures to prevent eventually running out of memory or slowing down due to memory allocation overheads.
(note that also the "build xy graph" express VI could be used, but I don't like express VIs)
Message 14 of 15
(479 Views)
Thats what I was looking for, Thanks!
Message 15 of 15
(467 Views)
