xy chart time
I am trying to create a graph with the x axis Being Time (column 0) and the y axis with the data (columns 1 to 5), But I cannot get the time to be correctly displayed on any chart I build.
I am using Labview 2014
Message 1 of 15
(1,150 Views)
Hi nunyabiz,
do you create charts or graphs? You mix those terms in wild order - and they are not the same in LabVIEW!
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Message 2 of 15
(1,147 Views)
I have tried both, and i couldnt get the time to show up correctly in either one.
Message 3 of 15
(1,140 Views)
OK, there are some major confusions. Looking in your attached VI reveals that there is no graph at all, but a table. Your description regarding columns fit that approach.
So i wonder:
Do you want to use a table (readable timestamp and values) or do you want to use a graph/chart (x-axis as time, but "resolution" limited an y-axis are values which are usually connected by lines, showing a "trend")?
Also you read material to "shift register" as this is essential for your approach you have. Using a shift register will remove all your local variables.
Norbert
Norbert
Expert: Geometry
Message 4 of 15
(1,134 Views)
Again you have a table, not a chart.
If the time display is not to your liking, you need to tell us what kind of time display you want. Do you want relative time instead (starting at zero)? You don't say what is "correct".
In any case, you should use built array, eliminating the counter shift register. You should also use a simple wait instead of spinning the loop like crazy, until the time is elapsed.
Here's a quick draft. FOr more sensors, simply change the N of the FOR loop or create an array of your sensor values in some other way.
Also, why is the table a control if you use it as an indicator? Why do you initialize with an array containing one column instead of an empty array?
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 5 of 15
(1,124 Views)
I deleted the chart that I was trying to get to work. I want to chart or graph the data in the table and I thought it would be less confusing for anyone trying to help.
Message 6 of 15
(1,109 Views)
You still don't say what you consider a "correct" time display.
Message 7 of 15
(1,103 Views)
I want to graph the time in the table X (1st column) to the data Y (column 1 and 2), but everything I have tried the time (X) does not show correctly.
Message 8 of 15
(1,098 Views)
Again: what is "correctly"? We still cannot read your mind!
Message 9 of 15
(1,087 Views)
Correctly would be the time as shown in the first column. Sorry to be so cunfusing but it makes sense in my head lol. So to recap I want to make a XY graph from the table with the time in the first column to be X and the data in the other columns to be Y.
Message 10 of 15
(1,083 Views)
