Hi Friends,
I've a waveform plotted from a Sound file, using the output from Sound File Read SImple.vi
But by default it displays Time (X-scale) and Amplitude (Y-Scale) with some scale coordinates as 0-0.02 and -1 to +1 resp
But my requirement is
- A real time control should be available to X-axis which would change the waveform display along x-axis when the value is changed.
- Say suppose initially if it is 0-0.02 on changing that control value waveform should display btw coordinates as 0-0.05
Pls help me in this context if you've come across the same.
-Suneel
