Actually, it's very easy to convert the number. As stated elsewhere, the LV timestamp is equal to the number of seconds since Jan 1, 1904. An Excel timestamp is the floating-point number of **days** since Jan 1 1900.
One of the reasons for this change is that Excel only does single-precision math (which is also why it sometimes gives different answers than LV) and the number of seconds won't fit in a single precision number with sufficient accuracy to be useful.
To make the conversion, first divide the LV timestamp value by the number of seconds in a day. This returns the number of days since Jan 1, 1904. Now if you want to change the calculation options in Excel to use 1904-based time, you're done. But remember that the offset is a fixed value so it is
a simple matter to subtract-out the number of days between Jan 1 1900 and Jan 1 1904. This way you'll get the right answer without having to remember to play with the configuration.
The result is a number that you can format in Excel as a Time/Date.
Mike...
