07-13-2009 01:45 AM
Hello everyone,
Iam new to labview and have to make an application where when the user presses a button the data in 3 numeric controls get stored in a table.
and when user presses the button again new values get stored in the next row.
I am not able to figure out how to do it.
Any help will be greatly appreciated. Thanks for your help in advance.
Raj
Solved! Go to Solution.
07-13-2009 02:22 AM
Hi Raj,
you can use the "Write to Spreadsheet file" function with true connected to "append to file".
Mike
07-13-2009 02:40 AM
You can use the "Event Structure" (to wait for the user input, button pressed) in a while loop so it waits repeatly for the command. Inside them you can use what MikeS81 said, for writting the necessary data in the wanted table.
For the program to wait for the button-input, rigth click the "Event Strucutre"'s border and select "Add Event Case..." option. Then just select your button and chose "Value change" at the Event box.
07-13-2009 04:26 AM
Hi Mike
I wan't to write the data to a table on my front panel not a file. How do I use the function given by you to write in a table.
Raj
07-13-2009 04:34 AM
Hi Raj,
you can use a 2d array which you store in a shift register. Use the "add array" function for a new line.
Mike
07-14-2009 11:49 AM
Hi Mike,
Thanks for your reply. But I was not able to solve my problem from the image you give me. So could you please send me its VI.
I was not able to make a shift register for event case which monitors when the button for updating table is pressed.
Thanks in advance
Raj
07-15-2009 12:57 AM
akath,
the shift register has to be at the while loop window, not at the event case...
Hope the following VI can help you
Rafael
