05-09-2014 03:23 AM
I'm currently programming an embedded application on the cRIO 9022. The application basically read inputs and must log data ( around 20 channels, acquired at a 40Hz frequency) on a TDMS file.
The problem i'm facing is that tdms writing eats up almost 50% of CPU.
I think the issue might be that I write only one point at a time for each channel. What is the best way to do that (performance-wise)?
Best regards
peper2001
05-09-2014 03:40 AM
When you work with file input and output it is always better to write more data at once then write less data multiple times.
For each file call labview has to go through several layers of OS which consumes more time.
I recommend you to take a bunch of data and write it down once.
05-27-2014 04:43 AM
I am maybe a bit late with my personal feedback, but I would just like to provide it.
Writing bigger data sets could be a good approach to resolve your current issue.
However, do keep in mind that this also has upper limits.
You should keep in mind that the memory footprint of your internal data (+ application) does not become bigger than your internal available memory. (simplified explanation)
Also make sure that you are not always reopening and closing your data log file.
This could also give performance issues.
If you plan to continuously write to a certain file, then it might be best to just once open the file, then continuously write to it multiple times and close it when all of your writing is done or your application stops.
05-27-2014 04:56 AM
For information, I used data value references to make a simple buffer that is written every second to the TDMS file. And CPU usage dropped to something like 15-20%!
Thierry, thanks for pointing out the potential issue with the memory usage. Indeed, when the acquisition frequency gets higher, the buffer gets bigger and the memory usage rises.
peper
05-28-2014 02:46 AM
Hello peper,
It is (like many things in life) always a balancing trick..
Or to (ab)use a well-known quote:
There is no such thing as a free lunch..
05-28-2014 04:16 AM
reduce file I/O by setting tdms buffersize
