write to excel from oscilloscope
Hello guys,
I control my  real oscilloscope with this code and I need to write the data in an Excel file.
How can I write data acquisitions from this program? I tried with the write to measurement file function but it does not work. Smiley Happy
labview 2018 accademy
oscilloscope Rohde Schwarz RTO2044
Message 1 of 8
(6,154 Views)
There are no signals given as input to write to excel file.
Nghtcwrlr
Message 2 of 8
(6,147 Views)
what is the signal I have to use to save data with that block?
if I use the signal that goes to the chart it does not work, and it is the same if I use waveform array.
Message 3 of 8
(6,129 Views)
There are several questions to clarify.
  • By "Excel", do you mean that you want to write data in Excel's proprietary .xlsx format?  For that, you would need to use the Report Generation Toolkit and create an "Excel Report".
  • An alternative is to write a "Delimited Spreadsheet File", a Text file with rows delimited by lines of text, and columns delimited by a <tab> (the default case) or perhaps a comma (in which case the file can be called a "comma-separated Values" file, or a .csv, which Excel can also seamlessly read, along with any other routine that reads text).
  • What is the format of the data you wish to write?  Neither Excel nor LabVIEW's "Write Delimited Spreadsheet" function will accept a Waveform as input, for example.
Message 4 of 8
(6,104 Views)
Thank you very much,
the waveform that I get from instrument driver seems to be generated using an array of double. Which is in your opinion the easiest way to print this array into a file?
thank you
Message 5 of 8
(6,095 Views)
thank you
I can't look at your code because it's a newer version than I have but...
If the VI's for your scope can output a waveform as a 2D numeric array (X in one column and Y in the other) then all you really have to do is use the "Write to Delimited Spreadsheet" vi and write it to a file.
By default that vi will make a TAB delimited text file, but Excel will have no problem opening it you just have to jump through a couple hoops first. Launch Excel and use File->Open to open the file. Excel will launch the file importer and if you read the prompts you will see you can click right through it.
=== Engineer Ambiguously ===
Message 6 of 8
(6,089 Views)
I used ''Write to Delimited Spreadsheet'' this is a screen. Waveform is a Sine, the plot about ''current data'' inside the loop is a sine, but if I open the data inside ''file.TXT'', I don't find a good data to plot the waveform. I want a file with a 2 column, but the file was not written like that.
Where do I wrong?
How can I see the format of current data?
program.PNGshot of display
Message 7 of 8
(6,071 Views)
Accepted by topic author King_Rob
You have the Array input on the For Loop set to Indexing and you have a 1 wired to the Count Terminal.
Remove the For Loop around the write section.
A For Loop with a count of 1 only runs once, that makes the For Loop itself superfluous.
Message 8 of 8
(6,060 Views)
