Hi all
I have created a proof-of-concept vi (hopefully shown below!). At the moment it is being fed with some arbitrary numeric and boolean data, but in the future will be fed by over 300 parameters from an existing system.
It is desired that the front panel will show a list of the parameters and from this list it will be possible to select exactly which parameters are to be stored. For instance, in this case it may be that I only want to store bool 2 and the 3rd numeric input, and so these would be selected on the front panel. The tabulated logged data will then simply be of 3 columns, titled 'time', 'bool 1' and 'number 3' - I do not want empty but titled columns etc. I understand in this instance I could use case structures but once there are 300 parameters or more the number of permutations of cases will be far to high to realistically code!
Any help will be greatly appreciated, thank you!
