wirte to hidde file
Hi all:
I have some question. attach see file please :
1-       I what if I run the application again i don't  want to erase the data but to write again under the last line
2-       I make the file hidden or as read only .. but I see that I can write to this file , how can I write if this file is hidden or read only
How can I do that
(2,266 Views)
Can you post the image of your block diagram or post your vi for lv 8.0?
Message Edited by muks on 06-30-2008 03:26 AM
(2,254 Views)
You have to use the Set File Position primitive for this purpose.
See the attached VI.
- Partha ( CLD until Oct 2027 🙂 )
(2,252 Views)
