windows error 998 by installing labview runtime 8.2.1 on windows xp
I got Windows Error 998 during installation of the labview runtime engine 8.2.1 on windows xp system. The installation with the same package worked on serveral other systems with the same os.
Any ideas?
Thanks a lot and best regards,
Michael
(2,665 Views)
Based on the message it appears it's having problems reading the file. Did you copy the files from a CD? From a network? The file itself may be corrupt. Try recopying the files to your hard drive. You may also want to check your hard drive for errors.
(2,654 Views)
