why my work doesn't work? i cant' understnd....
hi guys
i've made a software that is a protocol to comunicate between pc and a bord with automotive cpu by datasocket
it constains 2 modules called "shm" (sharm) & "cmt" (comunicator).
Shm is the user side while cmt is serial port side and this talks with the board
I can't understand why if i do run on 2 files (shm_test & cmt_test) the counting of sending and receiving packets sometimes stops and the count accumulate fails...
with a wait of 20 ms the problems is solved.
where i'm in fall?
thank you very much!!!
Dario
http://www.sd-studio.it - web design agency
(2,603 Views)
Hi Dario,
it is a bit difficult to debug your application, mainly because I am
unable to run and test it directly. Where did you exactly put the
wait function in your code?
Bye,
Matteo F.
(2,529 Views)
