10-06-2011 05:41 PM
In my vi,why input voltage couldn't display in chart ?
please see the attachment
10-07-2011 11:08 AM
Your AI and AO run a vastly different rates, thus you should place them in seperate loops. You should also pull the timing and start VIs before the loop.
(Currently, your error wire gets reset with each iteration, you might want to keep the errors in shift registers)
10-07-2011 11:20 AM
Thanks to tell me.But,could you please to tell me how to modify them?How do I make AI and AO synchronization?
THank you
10-07-2011 11:44 AM
10-07-2011 03:06 PM
THanks.But,why are these not others?Does it work If ai is 20000?
10-07-2011 04:15 PM
Yun Zhu,
You might consider looking at some of the synchronization examples which can be found under Help » Find Examples » Hardware Input and Output » DAQmx » Synchronization. I believe the Multi-Function-Synch AI-AO example would be a great illustration of what you are trying to achieve. This example uses both AI and AO and it is also synchronized using triggers. Finally, the data read in is outputted to a waveform chart similar to what you are having difficulty with.
Trey C.
10-07-2011 04:42 PM
I really refer to these examples.I changed my vi.But,I couldn't see the plot of the chart and detected frequency.Could you tell me what's the problem with it?
10-07-2011 04:43 PM
please see the attachment.
