why input voltage couldn't display in chart ?
In my vi,why input voltage couldn't display in chart ?
please see the attachment
Message 1 of 8
(2,376 Views)
Your AI and AO run a vastly different rates, thus you should place them in seperate loops. You should also pull the timing and start VIs before the loop.
(Currently, your error wire gets reset with each iteration, you might want to keep the errors in shift registers)
Message 2 of 8
(2,355 Views)
Thanks to tell me.But,could you please to tell me how to modify them?How do I make AI and AO synchronization?
THank you
Message 3 of 8
(2,353 Views)
Well, your ai runs at 10000Hz and your ao runs at 20Hz, so start there ;). If they should be really synchronous, run them off the same clock.
Message 4 of 8
(2,348 Views)
THanks.But,why are these not others?Does it work If ai is 20000?
Message 5 of 8
(2,332 Views)
Yun Zhu,
You might consider looking at some of the synchronization examples which can be found under Help » Find Examples » Hardware Input and Output » DAQmx » Synchronization.  I believe the Multi-Function-Synch AI-AO example would be a great illustration of what you are trying to achieve.  This example uses both AI and AO and it is also synchronized using triggers.  Finally, the data read in is outputted to a waveform chart similar to what you are having difficulty with.
Trey C.
Message 6 of 8
(2,318 Views)
I really refer to these examples.I changed my vi.But,I couldn't see the plot of the chart and detected frequency.Could you tell me what's the problem with it?
Message 7 of 8
(2,314 Views)
please see the attachment.
Message 8 of 8
(2,313 Views)
