why does TCP/IP transfer between RT and windows slow down
I use LabVIEW 8.6 and cRIO 9014 with NI 9215 and NI 9237 and NI 9411 modules.
I have used TCP/IP with RT FIFO to transfer data from RT to windows. When i had run the real-time VI, i used to get the deployment status as Free memory 80997K of 126268K (Total 64%) . Then, I run the windows VI to see the voltage plots read from TCP/IP, there was no delay in the graph update.
But now, i have added more code along with TCP/IP to my real-time VI. After i place the data into TCP, i decimate the FIFO array and measure the rms values of the 8 analog channels in the same loop.Parallely, I have to do voltage regulation, run linear and rotory drive in the real-time VI. In addition, i have some 20 shared variables in the RT to commumnicate boolean values between windows and RT.
Now when i run the real-time VI, i get deployment status message as -Free memory 65588K of 126268K (Total 51%).
And when, i run the windows VI, the analog waveform plot is very very slow.
how do i make the program run faster. i have broken my real-time VI into smaller SubVIs . While deploying, it shows all the shared variables and subVI names as deploying. Please let me know how to make the VI faster with all the functions
Thank you. Hema.
(2,692 Views)
Would it be possible for you to post your code?
(2,668 Views)
