04-26-2017 11:53 PM
I'm using tone measurements to measure frequency, but when the frequency below 10 Hz, the tone measurements give wrong output, it wont fall below 10 Hz
The frequency range i'm working on is between 0-100 Hz
Thank you
Solved! Go to Solution.
04-27-2017 12:02 AM - edited 04-27-2017 12:05 AM
If you'd attached the example VI, we could check this easily, but how many samples (or what time length) is output in one iteration? Is it possible that the sample length is too short to check low frequencies?
A high frequency requires a higher sampling rate, but a low frequency requires a longer total sample time. If the loop iterates very quickly, producing only a fraction of the wave in one iteration, then you won't be able to measure the frequency.
The default settings for Simulate Signal produce a sine wave with samples generated at 1kHz and a sample length of 100. This means that the sample length only lasts 0.1s. At 10 Hz, 0.1s is 1 full period. At lower frequencies, your 0.1s becomes less than a full period.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
