12-19-2008 01:04 PM
12-19-2008 01:52 PM
12-21-2008 03:26 PM
... However, if you really need access to a menubar, you can pass a reference to the calling VI's menu to the VI in the subpanel and manipulate it from there (create/delete menus, handle selections, etc...). Just be sure the plugin VI cleans up after itself when it closes.
Mike...
01-05-2009 12:47 PM
I read the Help and understand it is on purpose, however why?
I have functionality in the Run-Time menu that I want the user to access. I ended up hacking the same functionality with a tab control. It doesn't look as nice but it gets the job done.
01-05-2009 01:27 PM
The why is really rather simple: Logically a window can only have one menubar. So if you want a subVI to interact with a menubar that is the one it has to use and the way to get to it is through the menu reference from the top-level VI. In use this is actually a very clean and systematic way of implementing the functionality.
Mike...
01-05-2009 03:04 PM - edited 01-05-2009 03:04 PM
01-05-2009 03:28 PM
01-05-2009 04:02 PM
doug@southerndaqsolutions.com wrote:
I know how to interact with menu items in multiple VIs programmically, however how do I display the subVI's RTM when it is placed in the subpanel so that the user can select the RTM items from the subVI?Message Edited by doug@southerndaqsolutions.com on 01-05-2009 03:04 PM
As explained you can't and LabVIEW does not allow this for a good reason. It is accepted knowledge in UI design and considered bad UI behaviour to have a menu other than a context popup or anywhere else than under the title bar.
LabVIEW adheres to that and most probably would have to jump through a few hops too to actually make this possible at all.
Rolf Kalbermatter
01-05-2009 06:17 PM - edited 01-05-2009 06:19 PM
No he didn't answer why, he just offered an alternate solution. However modifying the parent menubar wouldn't work in my case.
But thanks, this is all I was looking for "It is accepted knowledge in UI design and considered bad UI behaviour to have a menu other than a context popup or anywhere else than under the title bar."
01-06-2009 07:55 AM
Not to make too much of it, but I did tell you why: A subpanel can't have a menubar of its own because (to quote myself), "...Logically a window can only have one menubar...". Maybe not as classy as Rolf's statement - but then Rolf is a classier guy.
Mike...
