why 5MHz output is not obtained in 6602 timer using labview?
I am using a labview program to drive the 6602 timer into generate 5MHz pulse. The output is not able to reach the frequency. what could be the reason ? The NI DAQmx driver timebase will set automatically to 80 MHz based on the request. Please sort out
(3,315 Views)
Can you post your code?
Randall Pursley
(3,240 Views)
