03-14-2011 02:05 PM
does the sensors in EVERLIGHT run wirelessly and are they copatible with LabVIEW ??
I don't think so, but you can use any sensor which has an analog output. Try to google "colour sensor wireless"
Pick the one you like. As long as it has an analog output, it will work in LabVIEW for sure 😉
03-14-2011 02:29 PM
what do you mean by analog output in sensing ??
03-14-2011 02:30 PM
The sensor gives an output from 0-20mA or 0-24V. A signal is an analog output
03-14-2011 02:34 PM
OK
but just I need the sensor to distingwish between 2 colors ..
I would not like to go to the deep and deal with frequencies and voltages ..
03-14-2011 02:42 PM
It's really hard for us to tell which sensor you should use, cause it doesn't have anything to do with LabVIEW in general. The only thing we can do is help you with the interfacing to LabVIEW. Unfortunatly you will go have to look on the net which sensors are available.
If you only want to see if a colour is there another possibility could be this. This one doesn't output a analog signal, but a digital signal (TRUE/FALSE)
Cruise through the website of "sick.com". They have the widest variaty in sensor techniques.
Good luck with your project
03-14-2011 02:52 PM
I apologize to you for any inconvenience..
and I would like to thank you very much ..
03-14-2011 02:53 PM
No problem, anytime. 😉
03-22-2011 11:56 AM
There is something with your description which does not make sense...
Why do you need a color sensor for your simulation? Obviously, it is not water that turns red when above a threshold and then blue again once it is below that threshold..
Are you using a sensor to monitor the changes on a computer screen? If so, then that might be tricky because other colors and ambient light will influence the signal. A color sensor will give you frequency and intensity. Now, if there are multiple colors detected by the sensor, it may give unexpected results...
Before going into too many details, what is it that you are trying to accomplish with your project? Are you building anything physical? If it is all software, then why not read the value of the color? How do you want this simulation to represent a "real world" system?
Clearly, there is something missing from your description.. You may indeed be trying to implement a Rube Goldberg machine. In any language, it is good to have clearly defined objectives and to try to simplify the solution.
