03-12-2011 02:03 PM
Hey guys ...
plz help me
which sensors are compatible with Labview?
THNAKS IN ADVANCE
03-12-2011 02:34 PM
There are too many to list.
What type of sensor are you looking for?
Can you describe what you are trying to do?
03-13-2011 04:29 AM
we need wireless color sensor ..
to distigwish between 2 colors ....
03-13-2011 10:10 AM
Most color sensors output a frequency directly proportional to the light intensity, the frequency is commonly a square wave. You can read the frequency of a square wave, depending on the DAQ you are using in LabVIEW.
Alan
03-13-2011 12:31 PM - edited 03-13-2011 12:32 PM
check out
I'm not sure that they have wireless products, but you may be able to attach it to a wireless device / interface.
As Alan mentionned these can be used with DAQmx.
03-13-2011 12:51 PM
Or if you are into Microcontrollers this would be a very good solution,
http://www.parallax.com/dl/docs/prod/acc/tcs230-db_doc.pdf
It is specifically designed for the Basic Stamp, but there is enough information to adapt it to , say a PIC, or my choice (always) ATMEL.
Alan
03-14-2011 01:06 PM
Thanks a lot for your coopertion
I'll explain what I want to do ..
I want to build Safety Dam System using WSNs ..
I will make the dam as a simulation .
The
water inside the dam is represented using blue color , when it exceed
predetermined threshold value then the color is changed to red.
The sensor is monitoring the dam . When the dam color is blue , the gate is still closed.
But when the dam color becomes red then the sensor reads the data and send an instruction to open the gate .
Note
, the red water decreases when the gate opened until it reaches the
threshold value then the water color is changed to blue and the gate is
closed.
Help me PLZ ,,,,, I need your help .....
03-14-2011 01:13 PM
Pick any colour sensor who will output an analog signal. Use the simples DAQ card with that to communicate with your software.
03-14-2011 01:20 PM
Migrant-bird,
Is this ALL a simulation? Do you really want to connect real world sensors to a real world DAQ? Is this a School Project?
Alan
03-14-2011 02:01 PM - edited 03-14-2011 02:04 PM
does the sensors in EVERLIGHT run wirelessly and are they copatible with LabVIEW ??
just I want to build a simulated dam using JAVA ..
the water is moved from bottom to top .. it starts with blue color then when it exceeds the threshold , the color is changed to red ..
put the sensor beside the screen and when it senses the red color then it reads the data and the action is " open the gate "
Note , the red water decreases when the gate opened until it reaches the threshold value then the water color is changed to blue and the gate is closed.
