05-30-2009 01:11 AM
Hi
Which PID VI is suitable for climatic control of a home.
This is just simulation.
There could be knobs for ideal temp, low setpoint, High set point,
P, I & D
Any ideas or examples?
05-30-2009 04:29 AM - edited 05-30-2009 04:31 AM
05-30-2009 07:23 AM
I was amazed to find that many PID controllers but none specifically for temp control. If it is there but in hiding then I'm keen to find it. If theres nothing like it I 'm keen to find a solution.
Regards
05-30-2009 07:35 AM
I would like to add a PID to a temp controller but dont know which one or how to start it .
Heres what I started.
05-30-2009 07:44 AM - edited 05-30-2009 07:45 AM
Take a look here http://en.wikipedia.org/wiki/PID_controller
As you will read here PID controller is a generic designation. Your first step will be to implement a PID controller in Labview. Then you are done you tune it to your application. If you buy a stand alone PID it is the same thing. Then you get it it just a useless thing. It is first then it is tuned for a specific application it will do any good.
05-30-2009 07:54 AM
I did take a look at this previously as well as the NI site on pid.
I m now looking for a Vi in the library that can be used.
I 've been lookin for a controller that has inputs such as P, I & D or gains but could not find something suitable.
Regards
05-30-2009 08:31 AM
http://ducati.doc.ntu.ac.uk/uksim/uksim'04/Papers/Mohammad%20Alia-%2004-11/paper%2004-11%20CR.pdf
It is not so hard as see here
05-30-2009 09:28 AM
So, theres no library function or Vi as such, it must be built from components of the library & the equation.
Regards
05-30-2009 09:35 AM
05-30-2009 10:04 AM
