08-29-2006 03:45 PM - edited 08-29-2006 03:45 PM
Message Edited by JoeLabView on 08-29-2006 04:46 PM
08-29-2006 04:30 PM - edited 08-29-2006 04:30 PM
My understanding of the feature is that, when you have it enabled, you can go probe a wire after a VI has finished executing and see what the last value was to pass through that wire. So to answer your question, the Retain Wire Values feature stores its data in memory. 🙂 I don't believe the feature enables you to see any value that has ever passed through a wire...only the last value.
-D
Message Edited by Darren on 08-29-2006 04:31 PM
08-29-2006 09:36 PM
Thanks Darren,
Let's see if I understood correctly.
You enable that feature, run the vi and it stops normally (for whatever trigger / event/ etc).
You place a probe on the wire after the vi has stopped, and you can see the last value on that wire.
So that means that there are memory locations assigned for practically all the wires within a given vi whose "Retain Wire Values" has been enabled.
Do I understand it correctly?
If that is the cas, it will help to keep probes clean instead of placing several of them while debugging.
My original understanding would be a nice feature for future releases 😉
Thanks Darren,
RayR
08-29-2006 10:21 PM
08-30-2006 12:25 AM
08-30-2006 05:24 AM - edited 08-30-2006 05:24 AM
Message Edited by TonP on 08-30-2006 12:28 PM
08-30-2006 05:48 AM
