in data 07-22-2014 10:23 AM
Hi
I uase LabVIEW 2012. Could you please let me know where can I find LabVIEW 2012 FPGA module to download?
in data 07-22-2014 10:24 AM
I believe this is the download you are looking for: http://www.ni.com/download/labview-fpga-module-2012/3088/en/
Here is the link for the 2012 Xilinx Tools: http://www.ni.com/download/labview-fpga-module-2012/3209/en/
in data 07-22-2014 10:31 AM
when I eneter my serial number in the forst link I get teh following message
Internal Error Sorry, but the page that you requested may have been moved or deleted. Search our site or use the links below:
I just need to downlaod the module which is like 450 MB. The Xilinx Tools is 5 GB
07-22-2014 10:41 AM - modificato 07-22-2014 10:48 AM
Where are you entering your serial number? I am able to simply download it using the webpage:
EDIT:
You could also try downloading it with direct links:
1. NI Downloader for FPGA Module 2012: http://download.ni.com/evaluation/labview/ekit/other/downloader/2012FPGA-Eng_downloader.exe
2. Installer for FPGA Module 2012: http://download.ni.com/evaluation/labview/ekit/other/downloader/2012FPGA-Eng.exe
07-22-2014 11:11 AM - modificato 07-22-2014 11:19 AM
Thank you for the direct links
The problem I have is my system is 64bits and I have installed LabVIEW 2012 64bits . is there any direct link for downloading 2012 FPGA Module for 64bits systems because it complains and asks for LabVIEW 2012 32 bits?
in data 07-22-2014 11:19 AM
And you have LabVIEW in a 64bit version also ?
07-22-2014 11:21 AM - modificato 07-22-2014 11:22 AM
I could not find a 64 bit download...
From what I understand, there is only 1 download for the FPGA Module. It should install a subset of the available commands in the 64-bit LabVIEW 2012. (See here for the info I was able to find: http://forums.ni.com/t5/LabVIEW/Installation-of-LabVIEW-2012-SP1-FPGA-Module-with-LabVIEW-2012/td-p/... )
*Perhaps someone from NI could address this more specifically.
in data 07-22-2014 11:38 AM
probabely I need to install LabVIEW 2012 32 bits as well to be able to install this driver
in data 07-22-2014 11:40 AM
For a lot of modules/toolkits for LabVIEW there are only a 32bit version.
There is not a 64-bit version of the LabVIEW FPGA Module. You'll have to install 32-bit LabVIEW to use the FPGA Module (as well as RT, and many of the other modules).
