where can I find LabVIEW 2012 FPGA module
Hi
I uase LabVIEW 2012. Could you please let me know where can I find LabVIEW 2012 FPGA module to download?
Message 1 of 11
(4,781 Views)
I believe this is the download you are looking for: http://www.ni.com/download/labview-fpga-module-2012/3088/en/
Here is the link for the 2012 Xilinx Tools: http://www.ni.com/download/labview-fpga-module-2012/3209/en/
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 2 of 11
(4,778 Views)
when I eneter my serial number in the forst link I get teh following message
Internal Error Sorry, but the page that you requested may have been moved or deleted. Search our site or use the links below:
I just need to downlaod the module which is like 450 MB. The Xilinx Tools is 5 GB
Message 3 of 11
(4,770 Views)
Where are you entering your serial number?  I am able to simply download it using the webpage:
EDIT:
You could also try downloading it with direct links:
1. NI Downloader for FPGA Module 2012: http://download.ni.com/evaluation/labview/ekit/other/downloader/2012FPGA-Eng_downloader.exe
2. Installer for FPGA Module 2012: http://download.ni.com/evaluation/labview/ekit/other/downloader/2012FPGA-Eng.exe
Message 4 of 11
(4,759 Views)
Thank you for the direct links
The problem I have is my system is 64bits and I have installed LabVIEW 2012 64bits . is there any direct link for downloading 2012 FPGA Module for 64bits systems because it complains and asks for LabVIEW 2012 32 bits?
Message 5 of 11
(4,730 Views)
And you have LabVIEW in a 64bit version also ?
Message 6 of 11
(4,723 Views)
I could not find a 64 bit download...
From what I understand, there is only 1 download for the FPGA Module.  It should install a subset of the available commands in the 64-bit LabVIEW 2012.  (See here for the info I was able to find: http://forums.ni.com/t5/LabVIEW/Installation-of-LabVIEW-2012-SP1-FPGA-Module-with-LabVIEW-2012/td-p/... )
*Perhaps someone from NI could address this more specifically.
Message 7 of 11
(4,722 Views)
probabely I need to install LabVIEW 2012 32 bits as well to be able to install this driver
Message 8 of 11
(4,713 Views)
For a lot of modules/toolkits for LabVIEW there are only a 32bit version.
Message 9 of 11
(4,709 Views)
There is not a 64-bit version of the LabVIEW FPGA Module. You'll have to install 32-bit LabVIEW to use the FPGA Module (as well as RT, and many of the other modules).
Cheers!
TJ G
Message 10 of 11
(4,708 Views)
