I'll bet the lightbulb for execution highlighting isn't visable either is it? The problem is that someone turned off debugging for the VI in question. Debugging code does cost a little time so people who typically run their applications in the development system will sometimes turn off debugging. (Building a standalone application forces debugging off automatically).
To be able to probe your routine, right click on the vi's icon in the title bar and select "VI Properties..." and go to the "Execution" catagory and make sure the box labled "Allow Debugging" is checked.
This should put things right...
Mike...
