what will I do after installing the hardwares?
I have installed GPIB interface card and labview5.1,and connected the devices with IEEE488 cables.Now I want to make a VI program for automation measurement,what will I do at first.I don't know how to go on.
(2,580 Views)
What i would do first is select/run the Instrument wizard from the Project menu to identify the device and see if there is already a driver for the device. Once you have the driver installed you should be able to build a measurement program quite easily. If there isn't a driver, then you may be able to adapt an exisiting one with the various string commands that should be supplied with the instrument. If you have trouble building a measurement program, then you may be able to adapt one of the examples which come with LV.
Hope this helps you get started.
Kim
(2,580 Views)
Hello Kim,
Check out the NI Developer Zone, it has lots of information about developing drivers. Here are a couple links from Developer Zone to get you started.
Search Instrument Driver Network
(Check for an existing driver on the network)
Development Topics
(If you can't find a driver, you'll need to make one)
Ray K
NI Applications Engineer
(2,580 Views)
