03-09-2007 06:54 AM
03-09-2007 07:02 AM
03-09-2007 07:05 AM
You're probably not going to see any speed increase unless there are problems with your code.
The IIOA is supposed to make it easier to communicate with instruments by using a wizard and generating the code behind the scenes. Since it does everything, it will also do the opening and closing each time, which will also take time. You can open once at the beginning and close once at the end.
You can see the code created by the IIOA by right clicking the express VI after configuring it and selecting Open Front Panel. Note that the code is messy because it is generated automatically.
03-09-2007 07:38 AM
03-09-2007 08:10 AM
