what means that error "the VI is not in memory"?
when i deploy(run) the host program from lvproj, there got the error "the VI is not in memory". what does it mean?
thank you for your time
i am looking forward your kindly reply ..
with regards
(5,681 Views)
Did you change the location of your vi?
(5,668 Views)
No, i didn't change ..
(5,648 Views)
Did u rename it?
(5,640 Views)
Hi, roxylat,
Its always good idea to post the code snippet where an error occured.
Anyway, you may have "the VI not in Memory" error if you will try to open VI reference by name. Help says "...If you wire a name string, the string must match the full delimited name of a VI in memory..." Compare following constructions (assumed that SubVI.vi located in the same directory as caller, and not in the library):
Andrey.
Message Edited by Andrey Dmitriev on 07-04-2008 11:11 AM
(5,637 Views)
