this is from LV help glossary:
"channel is a pin or wire lead to which you apply or from which you read the analog or digital signal. Analog signals can be single-ended or differential. For digital signals, you group channels to form ports. Ports usually consist of either four or eight digital channels."
Good luck.
Oleg Chutko.
