web publishing labview 9.0
Syed,
Thank you for the additional information. It might be helpful to try the following:
1. Run the code for your original application without remote front panels - does the memory of LabVIEW increase?
2. While running the code for your test application, close the remote front panels - does LabVIEW memory decrease?
Could you please post a screen shot of your VI?
Best,
Rachel D.
Message 11 of 15
(778 Views)
No the labview.exe size didn't increase for original application when there is no remote connection. And after running the test vi from remote pc internet explorer(IE) the size started to increase. after 2 min or so i closed the remote connection and the size of labview.exe ( in the task manger) stopped to increase but didn't decrease.
Message 12 of 15
(764 Views)
There are an awful lot of rundll32.exe 's showing up in that task manager.  I'm wondering if that is related.
Message 13 of 15
(762 Views)
Syed,
I was able to identify this as a known issue with LabVIEW 2009. This was reported to R&D (#182590) and was fixed in LabVIEW 2010. Here is the link to the current evaluation software download for LabVIEW. I apologize for the inconvenience.
Best,
Rachel D.
Message 14 of 15
(749 Views)
Thanks a lot for your kindness and it gives me immense pleasure that you people try solve other people problem . Thanks once again
Message 15 of 15
(734 Views)
