10-16-2014 05:00 AM
Hi guys,
I am making a app (labview vi eg calculator) which has to run on the server so multiple clients can acess it at same time.
1. should i be installing labview runtime on the server.
2. how to deport the application from my development-machine to server so it works as a web service
3. now that service is used by multiple clients simultaneously should the vis be clones
10-18-2014 01:22 PM
aparab,
1. Yes. I would recommend creating a LabVIEW installer because it can automatically deploy the web service.
2. See 1.
3. Yes. As a general rule of thumb, all web service VIs should be reentrant.
Check out this FAQ: LabVIEW Web Services FAQ
10-19-2014 03:09 PM
10-20-2014 03:00 AM
thanks Chris & Mike for your responses.
it will be made availablle on our company Intranet & 5-8 people may acess it at a time.
10-20-2014 09:30 AM
The point of my question is that the web server that you can but with LV is not very robust. It can work well for a limited number of users but has a lot of limitations — not the least of which is that some large corporations won't let them run of their corporate network due to security concerns.
Mike...
10-20-2014 09:40 AM
Thanks got the point,
yes but thts a pilot project we want to try!
if say the info is needed by less no of people say 5 & its on the intranet then its fine.
Wat was in the mind of NI when they implemented it & try continuing it, if its not that robust or usable.
