waveform graph x-axis into real time recording
Hey there,
I have acquired voltage off a LVDT through the DAQ assistant and connected it to a waveform graph. However, the x-axis says its 'Time' but its got the white line running across it even though no time has elapsed and the time itself has funny units to it. What I need on the x-axis is real time so that I can see the line register from left to write as time passes by. I have tried a few things like connecting the DAQ to a chart graph but it doesnt have the log graph which I need. I have also fiddled with the XY graph by connecting the DAQ assistant into the 'Y Input' but I am not sure how to input time into the x input.
If someone could help me with this problem, it would be much appreciated.
Gurung
(3,226 Views)
Hi Gurung,
in a first step I would advise to use the waveform datatype. That one has timing information included, which is handled by the chart/graph automatically...
(3,218 Views)
Hi there,
Is it possible for you to attach a vi file as an example as I am very new to labview and still learning the basics.
Gurung
(3,197 Views)
Hi Gurung,
what do you expect here? Wire waveforms to a chart:
check.png(DAQmxRead settings: n channels, n samples, 1D array of waveforms)
For learning the basics you should
- examine the examples coming with LabVIEW
- go through the Basics course on NI website
(3,192 Views)
