waveform daq assistant - Two signals appear the same
Hello Michael,
I think that this module always scans the lower number channel first, and if you have asked for the channels in a different order, the driver reorders them in software.  Therefore, it seems like your signal always mirrors the lowest channel physically scanned.  I think it is probably a good idea to look into sending your SCXI-1100 in for repair. To do so, you need to speak to a technical support engineer, which you can do at ni.com/contact.
Let me know if you have other questions.
Laura
Message 11 of 13
(688 Views)
Laura,
Problem solved!  I talked with a guy from NI application support.  After right-clicking on my SCXI chasis in MAX and selecting properties -->chasis tab, the "communicating SCXI  module slot" was incorrectly left at the default slot 1, instead of slot 2 which is the location of my data cable.  After changing this selection, my application worked perfectly.
Thanks for the time you've dedicated to helping me, Michael
Message 12 of 13
(682 Views)
Michael,
Thanks for the update - I am glad everything is working as expected now!
Laura
Message 13 of 13
(677 Views)
