waveform chart - legend font
LV2015, Win7 SP1
Greetings,  I'm hoping someone can steer me towards what I'm sure is a property node that I just can't seem to find.  I'm converting numerics (data) into strings, and I'm combining those with string labels to make a formatted waveform chart legend (pic is attached).  This allows me to retain the visibility check boxes and the formatting selection boxes that are available in the default legend, while eliminating the separate digital display boxes.  What I'm looking for is a property node (or other way) to set the legend font  --- or perhaps the string fonts prior to being sent into the legend --- to something that is monospace like Lucida Console for example.
Thanks!
-Heyla
(2,194 Views)
Accepted by topic author Heyla
Hi Heyla,
there is no such property for the legend strings…
But you can set the font/size at edit time using the standard font menu item!
(2,186 Views)
Ha!  I was making it harder than it needs to be.
Thank you, GerdW!
-Heyla
(2,174 Views)
