waveform chart continuous acquitstion x scale display time (s)
Hello RJP,
Here is an example program that shows the best method I've found to do this.  Basically what I did is I changed the DAQmx Read to be an array instead of a waveform.  This will make the waveform chart graph the y values vs. array index.  Then I used a chart property node to at a scaling factor to the x-axis with the Multiplier property.  I scaled the sample number by 1/rate so that it would graph time correctly.
I hope this helps, and have a good night.
Brooks
Message 11 of 11
(1,450 Views)
