09-30-2010 08:47 AM
hello everyone..my fnal year project is to investigate partial discharge characteristic on natural rubber blend.my supervisor has ask me to do block diagram that can measure voltage and current using Labview.can someone help me..urgent...thanks:)
09-30-2010 09:00 AM
Block diagrams don't measure voltage and current. Hardware does. So, you need to start by picking the right hardware. Then you can determine how to proceed. What kind of hardware have you picked out? If you haven't, then write out your requirements. What is the voltage range that you're trying to measure? What is the accuracy required? Is it DC or AC? If it's AC what is the frequency range? Do you need a lab-bench style instrument, or will a DAQ-based device do? How much is your budget? Lots of questions to write and answer before you even think about the software.
