Hello all,
I'm working with LabVIEW 6.0.2 on Windows 2000 service patch 2. I have two machines - one a development workstation, the other a portable. They are not the same machine, but both are fast pentiums running the same OS and LabVIEW version as mentioned above. I set up both of these machines myself out of the box and have had complete control of what was installed.
When I insert a "VISA resource name constant" into the wiring diagram on my development workstation, I can use the manipulation cursor (the hand) to select COM1, COM2, or LPT1. If I do the same thing on the portable computer, I get different choices - the visa resource names ASRL1::INSTR, ASRL2::INSTR, and ASRL10::INSTR. Such constants created on one mac
hine and then exported to the other create errors, although they work on the machine in which they were created.
Why is this happening? Right-clicking on the constants, they have the same properties; under "Select VISA Class" and then "I/O Session", "Instr" is checked. Nothing else is checked except "Size to Text". These properties are the same on each computer.
