visa configure serial port problem
Dear all
I am using RS-232 port to communicate with with instrument.Right now the instrument is not their so i have shorted pins 2 and 3 of connector connected to COM2 port so that what ever i am transmitting, i will get i back. Using Hyperterminal i am able to verify that whatever i am writing it is coming back.
But when using Labview 7.1 i am tring to communicate by first configuring the serial bus by using VISA CONFIGURE SERIAL PORT.vi
with following settings
Visa resource name=ASRL2::INSTR (Because COM2 port)
Baud rate=2400
Data Bits=8
Parity=None
Stop Bits=1.0(Equal to 10)
Flow control=None
End Read on termination Character=True
Termination=A
The VISA Congfigure is giving error. The error code is 1073807202
The above procedure is similar in Visa read/write examples provided..
I tries hard to fix the problem but all invain.
Can anybody help me in this.
Abhimaniu
(3,407 Views)
Accepted by topic author Abhimaniu
see here
I'm guessing your problem is #2 (you don't have NI-VISA installed).
Message Edited by smercurio_fc on 01-22-2009 10:42 PM
(3,405 Views)
I am not using National Insrument PCI-RS 232 card.
I am using the RS-232 supplied with computer generally and during serial bus search for NI Serial bus i was not able to search any NI serial bus connection.
Is it possible to communicate using VISA Configure,VISA read/write without using National Instrument Card???
Whether we need ALIAS name and "my serail port configuration" somewhere in the VISA configuration
Abhimaniu
(3,383 Views)
It doesn't matter whether you are using an NI serial card!
If you are using VISA (and you are), you need to install NI-VISA. The error usually means that you haven't. Open MAX and check to see what you have installed.
(3,377 Views)
