06-16-2017 12:38 AM
hello, I want to transmit a video file from one system to other system using two USRPs (N2932). How can I do this?
06-16-2017 10:02 PM
There's a fairly detailed "Getting Started" guide for NI USRP-2932 available here.
In that guide, it lists two places with examples that might be of use to you :
You can access the NI-USRP examples from the following locations:
• From the Start menu at Start»All Programs»National Instruments»NI-USRP» Examples.
• In LabVIEW from Functions»Instrument I/O»Instrument Drivers»NI‑USRP» Examples palette.
Probably you can find an example there that will help get you started with data transmission.
This white paper discusses Record and Playback for USRPs. It uses a different model, but it might also contain useful information.
