08-19-2009 02:05 AM
How to cut and combine an .avi file......? Let say a video file containing frame 0 to 100, frame 40 to 60 are unnecessary.
Solved! Go to Solution.
08-19-2009 06:58 AM
08-19-2009 07:29 AM
This thread has some details but some of the links are outdated. Find if it is useful and post back.
Mathan
08-19-2009 08:09 AM
AVI File format is a container file format. You can have different encoded content in it. You need an appropriate codec to decode the content. If the content is compressed it is in principle done in the following way
- Save a full image
- Save changes to the full image several times
- start from beginning
As human eye is more sensitive to intensity changes than to color changes the color information needs lower frame rate than the intensity information.
Thus the codecs are rather complicated and you cannot cut the AVI file at any position without decompressing it.
E. g. virtual dub can "Remove segments of a video clip and save the rest, without recompressing." I think it can be controlled by a command line interface.
08-21-2009 02:16 AM - edited 08-21-2009 02:18 AM
12-25-2009 05:43 AM
Hi hito88,
can you please post the vi you programmed. your help is greatly appreciated
06-24-2020 07:04 AM
