vi to send email not working
Hi All,
From NI discussiion forum posts,i got one vi to send email.
I tried to execute the same .When i executed it for the first time it automatically opened window outlookexpress(Only for the first time when i executed) upgraing and it was having two options outlook express and noneof these.I selected outlook express.
Then the vi run without error but fails to send mails.
I tried to send mail to outlook express.
I am herewith attaching the vi i got frm ni discussion group.
This vi able to send mail to outlook express only or to any?
Can somebody help me in finding why the application failed to send mail to outlook express.
I have to set up something?I havent done anything other than executing the vi.
I am herewith attaching the vi ...
Thanks in advance
(3,693 Views)
I don't think you understand the basics of the ActiveX functions. The VI is not sending to Outlook Express, it is using Outlook's ActiveX interface to start it and then send an email. You might want to talk to your IS department to set up Outlook Express as your email client. I know there are some changes to the security settings that have to be made though I don't remember exactly what. You must have only the base version of LabVIEW because all other versions include SMTP mail functions.
(3,686 Views)
what is told u is correct.
Today only i started to go through activeX,i was involved in some other database oriented applications.So ofcourse i have to learn before i have to use ActiveX.
Without using ActiveX i just managed to send mail.But i dont know to what extend it will be usable.I have to check more.
From where i can get good tutorials on ActiveX.
(3,683 Views)
Hi User_1,
I have two good examples here for you.  The first is a general ActiveX tutorial and the second is specific to LabVIEW and Microsoft Outlook.  The code is nearly identical to the example you found - you may want to confirm your network settings in Outlook.
ActiveX and LabVIEW
Thanks!
-Brian
(3,634 Views)
Hi Brian,
Thank you for the reply with the helping link.
Thanks once again.
(3,619 Views)
