very high sampling rate for measuring acoustic emission
 hi
please i need help with labview code for an experiment. I am new to the software and I have invested  time and effort to develping a code that will acquire acoustic emission data at the rate of 2M samples per second. unfortunately the latest code i develped gives negative time reading and time jumps on the saved data.after some time e.g 0.0000005 to 0.9999999 can be postive and sequential but suddenly the next reading shows -2.0000005 on the saved time column and the negative time reading keeps consistent. I use PCI 6110 card and my ultimate goal is to acquire the data points (amplitude and time) and save them sequentially. I also wish to design the codes such that it can acquire a certain number of samples for each pass e.g 60million sampls in total  , queue them according to the order of acquisition  and saves them accordinly without time jumps and and negative time values.I also observed that I dont experience this problem when I use very low sampling rates so i added a buffer but that hasnt solved the problem either. I have attached the codes in the post for assistance. thanks
(2,674 Views)
Hello Gness,
Please provide more information about your application. What do you have connected to the PCI? Is it a cDAQ? Using which cards are you acquiring the signal?
Daniel M.
Applications Engineering
www.ni.com/support
(2,610 Views)
