04-15-2006 02:38 AM
04-17-2006 10:31 AM
04-18-2006 12:20 AM
04-18-2006 04:49 AM
04-18-2006
11:09 AM
- last edited on
12-01-2025
12:10 PM
by
Content Cleaner
Alok,
The links below give more information on the questions you asked.
Using the LabVIEW Real-Time Communication Wizard: http://zone.ni.com/devzone/conceptd.nsf/webmain/A6F17EE4ADCAB99686256D5E0053E210
LabVIEW Real-Time Module User Manual: https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/user-manual-welcome.html
If
04-18-2006 12:21 PM
Adding more on to my previous incomplete post...
I suggest that you format your cFP controller from MAX by right clicking on it under 'remote systems' and install all the software over again on the controller. This should take care of the version conflict.
Once you pass your vi through the communication wizard, you would have to create an executable of the Normal Priority Loop vi and then FTP it over onto the controller. You can set this exe to be a start up exe and every time you reboot your cFP, the exe gets executed. The links below talk more about the Application builder used to create the exe.
LabVIEW Application Builder User Guide <http://zone.ni.com/devzone/devzone.nsf/webcategories/1309D7070FE5137C86256B5D00799A44>
List of tutorials and example programs about developing and deploying applications: <http://digital.ni.com/manuals.nsf/websearch/F91E5E2E84F8EDEB86256D2C0065460D>
Prashanth
04-18-2006 12:23 PM
04-19-2006 10:05 AM
Hi Albert,
links given by prshanth are quite useful, i came to know about the internal communication between the cfp and the host.![]()
Formatting the CFP is the best idea
......it helped me a lot....actually it removed some of the confusions....but focused the problem which is still here![]()
look i have the Labview 7.0 installed in my computer but how it has the RT version 7.1, (the CD of RT engine has also the version 7.0)..this is the reason i think it shows version conflict....
and when i try to update the CFP softwares according to Host machine......it shows both having 7.1...this is obvious...so now the query becomes why the labview having such version conflicts on host machine itself...\
Is this a correct reason or i am wrong somewhere? I just need to target my vi on CFP such that i will use it wihout any PC connected to it.
thanx again...
--Alok Trivedi
Pune
04-19-2006 01:34 PM
